Hi, Has anyone put stock duals from another V-8 Dodge on their V-6 Charger? Was there any problems with fitting and do you know what extra parts were needed? Thanks Joe
I know that some here have done this. You will need to get a driver's side heat shield - it helps to insulate the gas tank. Dem pipes get hoy, y'know.
Any exhaust kit that is made for the R/T will fit the 3.5L; they both share the same diameter on the pipes, from the cats back (2.25"). So unless the kit is 2.5" and larger, you won't need anything else extra but a heat shield like mentioned above and probably the hangers on the left side.
