remove the bezel that is around the radio, vents, and climate control and disconnect the esp and flasher bottons. to remove the bezel point the vents down so you can get your finger on the lip if the bezel and pull. there are about 6 clips that hold the bezel on. once the bezel is off the radio will come out with 4 screws, philips i think. once the four screws are out pull the deck out and disconnet it and your done. i just did this on my charger to put in a 6 disc factory CD player. very easy
