1 - 2 of 2 Posts
a friend spilled some car cleaner in his trunk, which leaked onto his fuse box. first all his gauges went out, the srs/airbag and trac ctrl lights would come on, no turn signals on inside(indicators outside markers worked) and his ac wouldnt work(climate control panel). i had him clean off all his fuses and dry out his fusebox, this worked for a bit. now his ac goes in and out when you try to turn it on sometimes it also makes the srs/airbag and trac ctrl lights come on. has anyone heard of this problem?
2006 dodge charger dont know trim level (not srt but has power everything and the boston acustic sound system).
thank you for anyhelp
ps all fuses are fine and dry. realys click as well.
Spilling liquid into electrical components is never good. Should probably take to a qualified mechanic to fix it. Welcome from So. cal.
1 - 2 of 2 Posts
