1 - 1 of 1 Posts
hello everyone,
i tried for days to enable "Sound Horn on Lock" on my charger 2010, i followed the instructions from the manual but no luck.
does anyone have the same problem?
i live in Kuwait in case the manufacture is deploying different software for each country.
below is what i found in the manual:
Sound Horn with Remote Key Lock
This feature will cause the horn to chirp when the doors
are locked with the RKE transmitter. This feature can be
turned on or turned off. To change the current setting,
proceed as follows:
• For vehicles equipped with the EVIC, refer to “Electronic
Vehicle Information Center (EVIC) — If
Equipped/Personal Settings (CustomerProgrammable
Features)” in “Understanding Your Instrument
Panel” for further information.
• For vehicles not equipped with the EVIC, perform the
following procedure:
1. Press the LOCK button on a programmed RKE transmitter
for at least 4 seconds, but no longer than 10 seconds.
Then, press the PANIC button while still holding
the LOCK button.
2. Release both buttons at the same time.
3. Test the feature while outside of the vehicle by pressing
the LOCK button on the RKE transmitter with the
ignition switch in the LOCK position and the Key Fob
removed.
4. Repeat these steps if you want to return this feature to
its previous setting.
Thanks.
1 - 1 of 1 Posts
