Thank you so much , I really appreciate it !That’s the belly pan. 4 10mm bolts hold it in place and it looks like the rear 2 bolts came off. You can either find 2 new bolts to fasten it back up OR you can just take the belly pan off. You don’t really need it.
I got u ! Thank uI havent been under mine yet, but if its plastic, you be able to zip tie it up until you replace the bolts. That should get you to the store for a more permanent repair anyway.
