1 - 4 of 4 Posts
I have an 08 charger 5.7 police package. I got a code p0520 and p0522 (oil pressure voltage low and oil pressure switch circuit) I replaced the sensor and now instead of those I get a p0523 (oil pressure switch voltage too high) please someone help any input would be appreciated
Did you do the install yourself? If so where did you buy the replacement part? Could just be a bad replacement oil pressure sensor. Return it or take it back to the shop you got it fixed at.
Sent from Galaxy.....S4 that is
Yeah, what Razorx said!
I'd bet you just got a bad one. Or, the person installing it broke it... (They seem fragile.)
The easiest thing is to return it and try another.
Oh, and double check it's the right one: Parts stores don't always give you the exact right part. The one from Autozone worked for me.
Or something could be shorting out in the connector or wiring. My predator can be configured to read out the voltage live, which might give you some clues.
I just did mine a few weeks ago, so I'll be interested to hear how you resolve this!
Same issue here. What part numbers to fix this? P0520 only
1 - 4 of 4 Posts
