1 - 16 of 16 Posts
well Some of you saw and some didn't I had my a,b and c pillars wrapped in Carbon theres still flat and need the clear coat but I thought Id share tell me whatcha think :)
ill get a pic of the A's tomorrow
What Exacly Is Carbon Fiber Some Type Of Mesh????
I think it looks good. Can't wait for in car pics.
Are you going to do the whole car ?
carbon fiber is a composite material.
Think fiberglass only stronger.
carbon fiber is used in some bullet proof vests.
airplane parts.
beoings new airplane the 787 Dreamliner is made mostly of carbon fiber. composite.
airplane parts.
thanks......got it:D
That gonna look super cool when its cleared, but im jus concerned about the whole for the seat belt? will that also be treated? painted?
What about the rest of the interior, its tan at the moment, is it staying that way? like a two tone, dark on top and tan on the bottom... either way thats still the coolest treatment i've seen... patiently awaiting final product, and goodluck...
Carbon fiber is a composite material most often found in race cars and expensive supercars although like all advanced technology it is finding its way into more and more vehicles. Despite it's expense and high-tech uses carbon fibre is relatively easy to work with.
The expense of carbon fibre is offset by it's amazing strength and extreme lightweight properties. It is also extremely stiff and body stiffness plays an important part in contributing to good handling, especially at high speeds.
Some production supercars use a carbon fibre monocoque, a construction technique that uses the external skin to provide support rather than the conventional internal frame. Other times the carbon fibre is used in the bodypanels or in areas where extreme stiffness and lightweight is beneficial.
Carbon fibre is sometimes used in conjunction with fiberglass because of their similar manufacturing processes, an example of this would be the Corvette ZO6 where the front end is carbon fibre and the rear is fibreglass.
Carbon fiber is however, far stronger and lighter than fiberglass.
Carbon fibre can be found in a wide range of performance vehicles including sports cars, superbikes, pedal bikes (where they are used to make frames), powerboats and it is often used in the tuning and customising industry where attractive woven panels are left unpainted to 'show off' the material.
looking good
Sick as always....
1 - 16 of 16 Posts
