1 - 9 of 9 Posts
Here are a few undocumented stats:
*One Top Fuel dragster 500 cubic inch HEMI engine makes more horsepower than the first 4 rows of NASCAR'S at the Daytona 500.
*Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
*A stock Dodge HEMI V8 engine cannot produce enough power to drive the dragster's supercharger.
*With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
*At the stoichiometric (stoichiometry: methodology and technology by
which quantities of reactants and products in chemical reaction are
determined) 1.7:1 air/fuel mixture for nitro methane, the flame front temperature measures 7,050 deg F.
*Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
*Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
*Spark plug electrodes are totally consumed during a pass. After
halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 degrees F. The engine can only be shut down by cutting the fuel flow.
*If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
*In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph(well before half-track), the launch acceleration approaches 8G's.
*Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
*Top Fuel engines turn approximately 540 revolutions from light to
light!
*Including the burnout, the engine must only survive 900 revolutions
under load.
*The redline is actually quite high at 9,500 rpm.
*Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs and estimated $1,000.00 per second.
*The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile. The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run.
--------Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The "tree" goes green for both of you at that moment. The dragster launches and starts after you.
You keep you foot down hard, but you hear an incredibly brutal whine
that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
------and that is ACCELERATION!.
Sure it takes the Z06 but hope there isn't a bend in the road shortly thereafter :grin: !
Interesting read, thanks! I've always been impressed at how quick and fast (and dangerous) those things are.
-J
Good read...it would never catch a Charger though :lol:
Put him next to me and see if he does that. :lol:
Hmmmmmmmmm....... I'll still beat him.
:lol:
__________________________________
2006 Torred Daytona Charger #1711
K&N cai, flowmasters, throttle body spacer, and one bad a$$ driver!:rockon:
wow thats some cool info. . :) . . i wouldnt mined getting behind that wheel once in my life. . 8 g's dam
less then a thousand revs before a rebuild........ can I get a warrenty with that...
Still wouldn't take a modded Cobalt or evilGTO
1 - 9 of 9 Posts
