I have a 2008 Dodge Charger se 2.7 v6... a year ago I received engine lights for the catalytic converter‘s on both sides. I replaced both of the catalytic converters and all 4 oxygen sensors also did the engine tune up. Now after clearing codes and unplugging the battery I’m receiving Codes p2096, p0133, p2096p... I keep erasing the codes and unplugging battery the same 3 codes keep coming back I don’t understand why. Can anyone help me please?
P0133 (O2 sensor slow response) can be caused by an exhaust leak. Check the exhaust from the manifold down through the cats and O2 sensors. P2096 is a lean fuel trim code. This can also be caused by an exhaust leak. Also check the O2 sensor wiring harness/connectors.
thanks a lot!!! I appreciate you replying to me I’ll look into what you said!!!
