That will be next ! I just can't wait to hear the cam lope!
Do it first, add cam second.
You would be surprised what a 3.92 Getrag will do for your car. The cam adds only a few ponies down low compared to what the gears will do.
The Max cam adds about 60 hp total and only around 20 hp down low. The gears will give more than that across the entire band to work with.
For example, with the 6.1L engine with the stock 3.06 gears you are putting down 125 HP and 325 lb/ft Torque at 25 mph in second gear.
With the 3.92 at 25 mph you are putting down 160 HP and 360 lb/ft Torque at 25 mph in second gear.
At 50 mph, the stock set up gives you 275 HP and 375 lb/ft Torque.
At 50 mph, the 3.92 gives you 375 hp and 420 lb/ft Torque.
