Thank you...!!! Thank you...!!! Thank you...!!!You are absolutely CORRECT... and I extend my apology to you (the only bidder so far)and the 'Watchers'...MY descriptive info explaining the 3 styles is correct... but then I goofed by going ahead and identifying this Magnum rim as that of a Charger... I would like to try and REVISE the posting to substitute 'MAGNUM' for 'Charger'... but cannot do so as long as your bid is present... I will necessarily have to CANCEL your bid to do so... and it cannot be reinstated... Tell me... Do you want a Magnum or Charger Wheel???... I an best straighten out the matter with you with a personal 'PHONE conversation, or... ... Call me briefly @ 360-________... then I'll spend the LD $$ by calling you back... In the meantime I'll cancel your bid and try to REVISE the posting to correctly reflect 'MAGNUM'... Again THANX for the correction... and accept my APOLOGY for the error...
