I installed my new headlights, front turns and fog Silverstars and while I was under the front end with both engine covers off, looking up at my K&N drop-in, I couldn't understand where the "fresh" air would come from. I saw a few people have purchased 4" duct work, and cut a hole to grab some air. So I took off the drivers side lower radiator plastic shroud, and thought... well now it should get some air. But then I got looking at the shroud and thought man this would be a cool scoop to direct fresh air to the cavity behind the headlight assembly, right below where the intake filter is. So I tried and it didn't fit. Then I cut a tab off and it fit perfect! But it was a little loose, and I could only imagine the thing flopping around. So I drill a small hole and zip tied it to the radiator support bracket (factory hole and everything) Check out my free how-to capture fresh air by flipping the shroud.
First, these are images of the OEM shroud in place, with both engine covers off.
