Going over the instructions I had a few questions-
Step #8 says (4) 1/4-20 flange nuts. I found in the kit: regular nuts, flat and lock washers. Not enough room for the locks so should I get some flange nuts or not use the locks?
Step #21 calls for PL premium glue, was it suppose to be in the kit? I did a google for that glue and find there are several different part numbers with the same title so don't know which PL premium glue to use and how much to get?
Step #25 says to load "both epoxy adhesives" neither of these were included in the kit, what kind of epoxy adhesive is recommended?
Step #27 says to use the squeegee provided, didn't get that either but I can manage if I know what two epoxy's should be used along with the contents size.
Step #33 says to bolt down the grilles into the scoop, nothing to bolt them to in there and we talked about that but remember someone posting a "how-to" on installing grille studs, I forgot where the post is. It would be helpful if you have a link on that "how-to"
Thanks :beerchug:
Thanks :beerchug:
