1 - 2 of 2 Posts
OK, I know this has been answered before here but I need a quick responce to this mod..
I almost got killed the other day by the ESP in my Magnum, Pulled out of a busy intersection and floored it, Tires break loose, ESP says slow down, Car falls on face and I almost get rear ended by another car...
Well I got so mad about this that I went home and did the No ESP Mod on my magnum..
Now I have a 2005 RT Magnum...
It works and the ESP/BAS lights come on but no Mr.Squiggles...
Is this normal for 05's??
If I hit the ESP button after I turn on the no ESP Mod then Squiggles show up...
I know I did this install correct... What is going on here, Is my ESP Off????
Anyone with an 05 please let me know...
Thanks for any help..
If you just push the ESP button and turn it off normally it should solve your problem. The ESP button turns off traction control and that is what is holding you back in the intersection. Although the car might still be applying the breaks to try and straiten the car out, if you give it enough gas it should over whelm the breaks and go any ways.
1 - 2 of 2 Posts
