after mentioning that I had written a review in another thread, it was recommended that I repost it in a new thread (with new title so people could see that a review existed within the thread - so without further ado, here it is:
Set-Up:
supercharged my '09 in 2012 while I was still stationed in Germany. procharger 8 psi boost on stock 6.1 with canned vortech tune. (only other mod is a catch can). ive put a little over 20k miles since then (including a couple nurburgring laps, and 100+ mi road trip at speeds hitting 150+ mph to get there with some coworkers) and have never regretted it.
Surge:
never dyno'd it, but should be getting just over 500 BHP to the wheels (compared to others with similar setup in the past), but drivability never changed from stock. low rpm driving is still a pleasure. note: there is a power band, but it's at/near 80mph steady-state driving where you get a small, but noticeable, "surge" effect.
Fuel Economy:
not much (if any at all) difference with my setup. I still get 19-21 MPG at TX interstate speeds (80-85) note: I don't grossly speed (nor would I ever promote doing so), but it's not unheard of for me to go 3-5mph over (except when passing - yes, it's extremely easy to hit 100 mph before my rear bumper reaches their front bumper). in town, she still hates residential speeds at 30 mph (SC or not!!) due to the way the tranny is geared, but with consistent moderate to heavy starts from dead stop I get about 14-16 MPG. again, about what you'd expect from stock 6.1
Reliability:
zero engine or SC related problems. as mentioned in another post there has been the rare occasion when my CEL comes on in moderately cold weather. but, as stated in the other post, the light has gone off (on both occurrences) after some spirited driving at or near WOT. I don't think this has anything to with the engine (regardless that the CEL is lit) or the fact that my car is SC'ed. as stated above I've got about 20k mi with the SC and 40k on the odometer. others with similar setup have had over 50k with no issues at all, or minor (easily fixable) issues with the SC itself in one case.
But, What does it feel/drive like?!?!:
note: all experiences given below are with General G-Max AS-03 275/40/20 tires on all 4 corners:
handling is smooth and predictable. at speeds near or above 150 mph the car is well balanced and solid with a bit more power in reserve. note: at these speeds with 275 tires there is a small, but noticeable "lag/sway" feel when changing lanes due to the ever so slightly wider rubber. it was felt initially when starting the lane change, but never was cause for concern. I only mention it here to be thorough. I never felt it on corners, only when changing lanes. nurburgring racetrack was a BLAST!!
Over 60: when mashing the "go-pedal" at speeds above 60mph the tranny drops gears appropriately, the tires grip, and the car accelerates (very quickly). possible to get slight chirp depending on incline/decline. as mentioned briefly above it takes only 2-3 seconds to go from 60-100. dropping the hammer at 100mph will STILL put you back in your seat very noticeably. acceleration from 100-150 (while never actually timed) is quick and noticeable. hard acceleration starts dropping noticeably above 140 (due to drag coefficient)
50-60: possible to get wheel spin (depending on incline/decline) for short period when mashing gas from speeds of 50-60mph, but not enough for traction control to kick in. light feathering or "controlled" stomp will get best results.
40 and below: moderate to severe heart palpitations (due to burst of adrenaline) may occur as the rear end attempts to pass the front end. nuff said :)
dead stop: stomping the "go-pedal" from a dead stop is not recommended for this (my) vehicle unless you like the smell of roasting tires in the morning (not to mention cleaning tar off the rear quarter panel)....or any other time of day really. for best effect, controlled feathering is highly recommended - at least until you've gotten to "know" her. on the better runs I've had (open highway stretches, pulling out from side street) it's not unheard of to get a "long" chirp (as opposed to "short" chirp, or wheel spin) when shifting gears around 60-65 mph, especially on the "harder" shifts. note: tranny can be a little finicky. if too cold she can/has hit the rev limiter and fluttered until I (while moderately panicking) manually attempt to "make" her shift. but, once she warms up she veritably SLAMS into gear....hard and fast. this could be due to the extra power I'm pushing, but only happens when the engine/trans is cold. I've never pushed her so hard that she got heat soaked (engine or trans), so I am regrettably unable to speak to that point.
the only other thing of note is the infamous super charger "whine/whistle." my car really doesn't have any noticeable whistle **from the SC itself**. the blow-off valve, however, is another matter entirely. it does whistle (when not boosting). loudly. annoyingly so, and it WILL be fixed (one of these days :)
I hope this little mini-review of my supercharged (but otherwise stock) 2009 Charger SRT helps (anyone looking to do the same) make an informed decision. all-in-all I highly recommend it. for those who are interested, it cost under $11k total with installer being paid in Euros and having to be shipped to Germany via USPS.
while I appreciate the clappy hands, I thought an in-depth review would warrant at least one comment. is this review really that bad? or are folks really just not that interested in the topic?
This forum isn't nearly as populated as LX forums, it seems there's only a handful of active posters here. You'd probably get a ton more replies over there.
As far as on topic, I'm looking forward to adding a supercharger myself next summer.
Motor is all stock? I would be hesitant to put 8lbs on my motor, I'd feel safer with 6lb.
What does your in dash HP meter read?
Actually a very good review, and not overly technical for us un-supercharged folks in the audience.
I have been following a couple of threads where folks have put a SC on their 6.1 Charger. I have an 06 SRT, and there is a SC in it's future, maybe a year or so off.
Good to hear it'll handle 8psi; I was probably going to play on the safer side and max at about 6. Mine is all stock internal, and would like to keep the internals, well, internal. :wink3:
I'll stay tuned to this post to see/hear any further developments or news.
Thanks!
I sure wish I had a few thousand bucks laying around to S/C the R/T. I know I could get into the 400HP numbers without a S/C, but nothing beats that nice whine and the surge in power you get throughout. Enjoy the F out of that sucker for us, will ya? :rocker:
there is no in-dash HP meter (that I know of) on the 6.1's...and, judging by your sig photo you're running a 6.4
yes, the motor is stock, but there are two (major) things that determine how much boost an engine can handle:
stock compression (or rather final compression after boost): 10.1 (6.1) vs 10.9 (6.4)
and piston design. (note: piston design also determines stock compression)
I can't intelligently speak to piston design (though I would hope/expect the stock pistons can handle at least a moderate boost in HP), but the compression ratio on the 6.1 is a bit lower than the 6.4. be careful: overboosting a stock 6.4 could cause too high of a compression ratio (that's when bad things happen). as you say, I think 6 PSI might be safer for the 6.4 - ask around, I know there are some 6.4's on this forum that have been supercharged. (or hope they see this review and post here)
not positive, but I think your '06 should be able to handle 8 PSI as well as mine (if you're interested in the extra boost). I know there were some changes in model years between 06 and 09, but it really handles the boost rock-solid. talk to whomever you purchase the kit from - the guys over at speedlogix (where I purchased mine) were very knowledgeable - and one of the guys actually had a SC'ed (stock) '06 (I want to say it was Chris, but not quite sure) - that's why I bought mine from them....
Kind of surprised to see you use a canned Vortech tune for a ProCharger though.
not a lot of options in Germany :) and, it came as part of the kit and seems to work well. but, as I said, I haven't had it dyno'ed. if ever I do dyno, perhaps I would be able to get a custom tune then - or maybe later on when I (plan to) upgrade the CAM to one designed for SC'ers I will get custom tune....
