What exactly is a rev limiter? I know when you are in P or N you can't rev past 4k, but what about when you are in gear? When in auto stick and you floor it till it shifts, is it shifting because it hit the rev limiter, or because it hit a shift point? If you have your shift point set at say 6100, and no rev limiter and you were in auto stick could you blow your motor if you kept the pedal to the floor?
