1 - 4 of 4 Posts
How do I connect the remote wire from AMP in the trunk. Pictures would be highly appreciated.
Hello,
If you mean how/where to run a wire for a remote turn on for an amp....
At least in my 2013 Charger SXT
Under the trunk deck, to the rear of the battery is a fuse box (fusebox location pic).
Open by pushing on the latch on the left-hand side (fusebox latch pic)...push on the top of the catch.
Under the lid is a listing of the fuses (fusebox cover pic). that lists what the various fuses are for.
I don't have an amp wire hooked up at the moment, but you want to pick a location that's on when the car is on.
I previously used a fuse tap (http://www.streetsideauto.com/p/wirthco-30800/?utm_source=googlepepla&utm_medium=adword&gclid=CMGg0crp0MYCFZKBaQodXZ0HiA or, you can buy similar in a lot of places) in the 51-58 range...I just used an empty spare (fuses pic).
I had to try a few to find one that was switched (only on when the ignition was on).
Hope this helps...
thx, I actually used a share a fuse product that worked nicely with the cigarette lighter fuse
Recommended fuse
I tried the cig lighter ign fuse #12 but found it only came on after hitting the ign switch. It does not come on when remote starting the vehicle. I will be adding lights as well as the amp and prefer them to come on with remote start so I am using fuse 44 10amp-Park assist/blind spot/camera. Unfortunately I can not close the cover now in that spot without modifying it to fit the fuse splicer in that spot but it works perfectly. It powers on as soon as I remote start the car and it shuts off when hitting the kill switch to turn the car off.
2016 Charger SXT (fuse cover matches)
1 - 4 of 4 Posts
