1 - 6 of 6 Posts
Other then the obvious head unit, antenna and bezel what else needs to be changed to make this work? I'm looking at a REC unit but i'm not sure what else needs to be done. Is this a plug and play mod? My other concern is the failure rate in these units. Obviously dodge won't replace it because it's not factory if it fails. This system isn't cheep.
Nothing else needs to be done other than taking out the white plastic support that is behind the current radio. I changed mine, routed the antenna to under the left dash speaker and have had no problems.
i would really like to do the same thing. how much would it cost?
1 - 6 of 6 Posts
