1 - 11 of 11 Posts
It seems I have joined those who have had the 6-disc changer fail on the REC headunit. I can change discs at will, it loads and unloads fine. Every disc, however, reads disc error.
I tried pulling the fuse to 'reset' the radio, but it didn't have any effect.
I bought this headunit new off of eBay, which was apparently another in a long line of errors on my part. It has functioned flawlessly for months, but now that it is broken, I am up a creek - the seller won't answer my questions regarding a warranty and my dealer... well, it didn't come in the car when I bought it, so...
There is a local place that will repair it, Caton Radio in Caton, MD, but they charge a flat rate of over $600 to repair NAV headunits, regardless of the repairs done. I would then have a warranty for a year on the whole thing, but still...
Anyone have a source for the changer mechanism itself? I'm reasonably competent and pretty sure I can swap the changer out if I had a new one to put in.
Discussion Starter · #2 ·
So I'm guessing from the deafening silence that no one has sourced the changer itself, eh?
Have you tried using a lens cleaner?
Yep, I sure have.
Man best of luck to ya.....Try and talk to a man called MR INCREDIBLE over on lxforums dot com. He does Nav repair I believe.
Scott
If Mr. Incredible can't help you then you may have run out of options. I doubt the dealership will service it since you didn't buy one from them or that it didn't come with your Charger. And since you bought it off of eBay there's a chance that it was stolen out of a Charger. But best of luck to you.
No, it wasn't stolen, it was brand new in the box, still had the plastic on the screen and not a mark on it, and the seller seems to move a fair amount of OEM radios. unfortunately, he doesn't appear to offer any sort of warranty, as he hasn't responded to my request for assistance. I'll try Mr. Incredible, thanks!
If he hasn't responded after several attempts, then report him to ebay directly. They may get a response out of him, for fear of a bad rep!
I too bought a used 6 disk off a guy, it works fine and all. But I've always wondered if it did break, and I was still under warrenty.....
Would the dealer really know that it didnt come with the car????
I'd doubt they'd go pull the VIN for stuff like that
They would have to, because Chrysler would be paying for that new headunit.
1 - 11 of 11 Posts
