1 - 4 of 4 Posts
Hi guys!, I recently got some brand new 275/30r22 nitto invos for $90 each brand new. I also get some lorenzo wl197 in 22x9.5 and 22x11 and realized I would need two bigger tires for the rear but am just having some trouble deciding if I should go with 285/30r22 or 295/25r22. I'm limited to these sizes because there's a deal on them at my work. I don't want to mix different tires tread and nitto doesn't make a 295/30r22 in the invo. I guess what my main question is which size would you guys go with and also will it rub on a stock height 2006 charger SRT or will I have to roll my rear fenders? Thanks again guys!:bigthumb:
Width-wise the 295s will fill those 11" rims better, and provide a better contrast to the front 275.
the diameter will be slightly less than stock @ 27.8 inches.
The 285s will only be marginally wider (roughly 1/2 inch) but on a 1.5 inch wider wheel. The 295s will get you almost an inch more width and fit better on a staggered look.
BTW, how about some $90 INVOs my way... I will just take 4 275/40/20 please :)
I lucked out with the 275 invos, I work for kal tire and there was a wearhouse clear out on them! I ended up going with the 285 simply because I didn't want less OD on the rear tires. I lucked out with the 285 as well and picked them up for a cool $150 each! If you want to see them check out my pics on Instagram my name ttboy125
1 - 4 of 4 Posts
