1 - 6 of 6 Posts
I don't know if you can call it aftermarket. That would suggest that it was something sold for that purpose. It looks to me like someone found some kind of block in the alley and wedged it in there. Does the other side have the same looking pieces? I'm guessing someone did this to raise the backend, either because the spring was getting weak or they wanted a little extra lift (minimal at best). You can pop them out, but you may find you need new springs.
· Premium Member
That looks like a KW lowering kit that someone put spacer blocks in to raise it back up.
It's a 2" drop kit from what I can tell. That's pretty low on an SRT.
Thanks.
With 79k miles on the car I would hope the springs are not worn out.
I'm not sure if the car had been lowered or not I saw another picture after I posted this of a SRT with the same springs and shock. The car does have 22"'wheels with 265/35 tires all the way around.
So maybe like the other person said to raised it up a little.
I did see one other picture of a SRT with the same setup so I'm not sure if it's factory or not.
Here is a picture of the car. 265/35-22 all the way around.
· Premium Member
It's not factory and with the 22s on there, I understand why they "lifted" the lowering kit.
It's a car that had been lowered and then lifted to fit those wheels.
1 - 6 of 6 Posts
