Mine does the same thing but nothing like yours. I get a dust build up on top of the bumper.
As Junkman2008 said, your not getting all the water out of around the tail lights. Here is what I do.
After a wash and before I dry it, I use a Leaf Blower to blow out all the cracks around the car. I spend sometime getting out all the water around the Tail lights as they hold water well. Then I dry the car with a super soft Microfiber Drying Towel from Adam's Polishes , I also have a Chemical guys and the Rag Company's Models but I like the Adam's the best.
Once the car is fully dry , my very next step is to open all the doors, trunk and hood. I clean all the jams with a spray wax or detailer. Then after the jams are done I close the trunk and see if any water runs out which sometimes or most of the time it does. I get the leaf Blower and blow the back end again. If you don't blow out the water, it will run out and cause your back end look. I think that's why you have a much dirty rear end .
I like the idea of Mud guards on the back end. I have thought of that myself . Not a bad idea my friend.
Now dispite what Junkman2000 says which he is right by the way , I will use a waterless wash spray and a super soft Microfiber towel to dust off the dust as it drives me insane. I use the proper technic to minimize scratching. My car is always coated and topped with toppers so I got a good amount of protection and minimize scratching even when using a waterless wash. You can also use a detailer as most higher end detailer have a good amount of carnauba wax with synthetic lube agents to help glide over your paint. You also need to use a high quality Micro fiber towel which if you don't , you will absolutely fine scratch your car due to the poor quality of your towel.
Here is what I use
eagle-edgeless-500-ultra-plush-microfiber-towel
These are what I use to remove waxes , sealants , coatings ( they go in the trash after a coating ) , Detailers or Toppers. I will use them for super light waterless wash jobs like the rear bumper top and back end of the car due to the dust there and no where else. I have waffle towels that are designed for Waterless wash use and they also work pretty well they just don't feel as stupidly pillowy soft was the 500's do.
adam-s-microfiber-waterless-towels
Again I have these towels and they work well with a Waterless wash as on my White Durango I used them and never saw a single scratch. One my Charger which is Pitch Black I hesitate to use them and go for the 500's as they are so stupidly soft and the technic I use to remove the dust , I have yet to see a single scratch from doing so. I flip the towel over after 1 pass to remove the dirt and rotate the towel while doing so so when the dirt is captured in the towel it's not sanding the paint as I continue to do so. Then after the dirt is removed. I use a new side of the folded towel to wipe away the rest of the waterless wash.
I don't recommend doing this when it's as dirty as yours I only do it when it's light dust and it kills me to leave it. I also like Junkman2000 suggests is I much prefer to do a full wash then use the Waterless washes.
