Look what I got a Picture of in an E-Mail..
I have been collecting parts for some time on this build and I couldn't have done it without the help from these Companies and many of the forum members here..
Huge thanks goes out to Odyssey Batteries, XS Power, Mechman Alternators, American Bass, Toolmaker Metalworkz and of course CSCStang for a Custom box.
Parts List as of now...It may grow :thumbsup:
CSCStang - Custom Box
Mechman Alternator - 240a
American Bass 4480.1D Amp 2200 @ 1Ohm
American Bass XR-12 1200w RMS
Odyssey PC1350-A for Main Battery
XS Power XP750-CK for 2nd Battery
Toolmaker Metalworks - to me announced.....
My goal here was to really improve the Bass and not get to carried away with over all weight. Reasons why I went with a Single Sub set-up, Smaller sized Amp, Birch wood and a smaller lighter weight 2nd Battery.
Now as I post pictures and start this build. I will need some help and have some questions. I'm sure of it. I will also be giving my opinion and reviews on products as I go.
I noticed with my old set up. Just a single Memphis PR 10inch. That a lot of my bass was lost before it made it into the Cabin. So To fixed this issue. I'm moving up from a 500w set up to a 1500w-ish set up. I'm also running a 6 inch port through the rear deck. The sub will be firing off the side of the trunk just behind the seats. The port once it is through the rear deck is about 1in away from the back glass(at its closet point) I'm hoping the combination of all this will dramatically improve my Bass.
Also with my last set up. Just that 500.1 Prime Amp pulled enough to Dim my lights and slow my idle at hard bass hits. So to help fix this b/c it was already a problem and I knew it would just get worse. I'm jumping up from a stock 140a Alternator to the Mechman 240a which as an idle output higher then my stock could put out at max. I'm also switching out my Stock Lead Acid battery for a Big AGM from Odyssey and a 2nd Battery from XS Power. I will be also adding a BIG 3 kit. My car already has a 0g from Alt. to Battery. So I will be adding 0g for my grounds and a 0g from Alt. to Starter.
That's were I'm at now... If you see anything I need to address. Let me know...
Did you get those 4"'s to fit in the dash? I replaced with 3.5's, but there are some 4" Morel or a few others I'd like to try.Got some more in today...
Front4" Dash Speakers... I'll be running these or a set of 3in Mids from Addictive Audio
Thanks, It could be a battery issue, A 2nd Battery was needed when I was just running 500w on my old set up. My issue was to reduce the headlights and Dash lights from dimming.dude so much time and detail put into this. It looks amazing. Here is my lazy sub set up hahaonce you lift the trunk thing to see the battery there are just wires everywhere because I took the whole setup from my old car that I had to run everything from the front of the car back.. Is running a stronger battery with a sub and amp recommended? I sometimes have weird cold starts where the car will stutter and throw the ESP BAS lights and I just have to start it one more time.![]()
I haven't fitted them yet, but I have read others have used 4in with no problems a dermel didn't fix.Did you get those 4"'s to fit in the dash? I replaced with 3.5's, but there are some 4" Morel or a few others I'd like to try.
This is a beautiful build. I can't even come close to how nice that looks!
But I recommend, with that work you are putting in to that system, adding some sound processing to take it to the next level.
Looks great! :bigthumb:
Somehow though, it makes me think there should be fish in there...
:grin2:
Maybe Bass?:biggrinjester:
Funny guy... Showed my son and thought I should do that.
Anyone know any fish that can handle the bass?
I hope you post, I want to figure out a way to do that and preserve the ability to return to OEM in case I sell the car. That's why all my equipment is surface mounted with no major mods. I can get back to OEM pretty easily, a buyer would just end up with some nice speaker wire.Thanks, It could be a battery issue, A 2nd Battery was needed when I was just running 500w on my old set up. My issue was to reduce the headlights and Dash lights from dimming.
ThanksVery clean work. The difference between 'good' and 'expert' install is all in the details...and this is a quite an expert install. :bigthumb:
Thanks and I can't wait either,I'm not very knowledgeable when it comes to car audio stuff, but this is an awesome thread and I cant wait until we see the final product.
They will have some sort of spacer or Shrink tubing on them for the final install.Those reducers are just waiting to arc! Hopefully no movement in there.
