1 - 4 of 4 Posts
Hello every one i need to know if an R/T stock exhaust system will fit onto my 2.7 L v6
Thanks
Thanks
It will. It will also likely reduce any low end you currently have.
You should also add insulation to the left fuel tank if you do this.
Why do I need to insulate the tank? Does the system touch it?
The muffler does not/should not contact the fuel tank. The muffler WILL radiate heat to the tank, and its contents.
The R/T comes with insulation on both tanks. The V6 comes with single exhaust/half the muffler so the factory did not needlessly insulate the other tank. If the factory engineers decided insulation was to be installed between the fuel tank and muffler, I am making an educated guess that there was a logical reason behind this decision.
You can get aluminized insulation cheap by the roll at most hardware stores, I got my roll for five bucks along with some double backed sticky tape.
1 - 4 of 4 Posts
