Question about the trim around my gauges
1 reading
7.2K views 24 replies 15 participants last post by  07CHRGRSRT8
#1 ·
I want to paint the trim around my gauges and the inserst in my steering wheel. I went to a dealer near me that has done this for the dealer where I bought my car. They told me that the whole panel has to come off and be taped and I will be out of a care for a few days. I know I am not the only one that has thought of doing this, so I am turning to my fellow Charger peeps for help. It seems like just the silver part might come off from the rest of the panel. But I would like more info before I decide to let these guys take apart my dash.
#3 ·
What are they, stoned? The trim rings come off separately, all you have to do is pull evenly while yanking them. The issue I have with Dodge is that they don't sell these rings separately. You have to buy the complete panel, and it ain't cheap. I've already purchased a spare nav bezel and need only another shifter bezel and trim ring set so that I may also paint the ones I have now.
#4 ·
Try sending a PM to TBYDaytona40
He did both, I believe. He should be able to give you some pointers/advice/instructions.
-=FLEX=-
#11 ·
wow crazy luck that looks awesome! and nice picture taking skills btw lol. did u just get the gomango paint from the dealer? did u use plastic adhesion promoter? and how in the world did u paint the chrome on those nobs??
theres probably a thread explaining all this isnt there? lol
#12 ·
I just used 3M scotchbrite pads to scuff the rings up, primered them and then used aerosol touch up paint from the dealer followed by a couple coats of clear.
The rings on the radio, those are a little more involved, I'll try to do a writeup on how to do them if I have time.
#15 ·
my list of springtime projects keeps growing..... i'm thinking dark blue....
#17 ·
oh just do it yourself. Call me and I'll walk ya through it on the phone. We'll do the cheater way, which is how I did it. Maybe I'll tell ya how to paint the emblem on the air bag too :)
#21 ·
I did mine and thought I'd add a couple of things *not* to do! :)
The rings around the gauges come out; just pull evenly. They are held by fragile little clips, which are easy to break. :( Don't do this when you're stressed out.
I couldn't get the yellow krylon paint at the time I did mine. So, I used plastic primer, then a regular yellow paint, then a clear gloss. It was good for a while, but sunlight apparently damages it a bit and the original mirror smooth finish doesn't look so good now. :( So, definitely make sure you get suitable paint.
Interestingly, my plastic airbag cover was slightly bent and deformed on one corner, which I just hadn't really noticed before. I heated it gently with a hairdryer and was able to correct this a bit. The instructions posted by TBYDaytona40 on how to remove this are good. It's actually easier than it sounds!
I would try it yourself!
#23 ·
but they don't sell the rings seperately?
i'd love to do this to my SE...
Don't buy the trim rings...waste of $$$ IMO.
I just did mine not long ago. I bought a small can of Krylon 'metallic' spray paint for about $2.50, pulled the rings off carefully; painted them with a couple coates of the spray paint and then a couple coats of clear and they look great (matches the steering wheel inserts).
Just do it yourself...
#24 ·
Hello All,
I had the trim around my radio / navigation unit, the ashtray, shifter trim and the cluster trim painted inferno red. I removed the pieces and brought them to a local body shop. They charged me $100, which I thought was an excellent price. The wood kits cost more than that and the painted trim looks much better. I had this done in June and eveything looks perfect. The good thing about having the body shop paint the pieces is they bake the paint and it has a hard finish. If I knew how to download pictures I would shoot you a few.
