1 - 18 of 18 Posts
I have a stock 2012 Charger R/T AWD.
I plan on doing the brakes and looked at Rock Auto and there were a lot of options.
It is a NON-POLICE model.
Is there any way to know if I have dual piston calipers?
I think they also wanted to know the diameter of front and/or back rotors.
Also, would the back rotors be solid or vented?
I'd like to have everything on hand before I start this so I don't have to rip into it twice.
I was planning on going with the slotted/drilled rotors.
12.6 front and back rotors. Yes all 5.7s have dual pistons. And you can run your finger along the rotor to see if it’s vented or solid. I want to say vented.
All the AWDs have the BR5 package (standard on R/T): 13.6" vented front rotors with dual piston calipers / 12.6" vented rear rotors with single piston calipers. Front pads have 1058 in the number, rear pads are 1057's
I bought the following from Amazon:
Power Stop K2853-26 1-Click Street Warrior Z26 Brake Kit
Currently about $430 but a serious upgrade on my 2011 R/T AWD.
You will like the rotors (I have PowerStop drilled/slotted rotors on all three of my cars), it will be interesting to see how the Z26 pads perform: I had Z23 pads and they stunk when cold (I replaced them with the Raybestos EHT pads). The Z37 Top Cop pads I use with the BR9 brakes stop great hot or cold.
I had them installed last year so I have just used them through a great lakes area winter and they were fine. I was a bit worried myself but no issues.
Discussion Starter #10
I bought the Raybestos EHT brakes and new rotors. I will install them this, or next weekend and advise how thy are.
Also running EHT pads on an R/T. My fronts are down to 4mm and the rotors look fine (rotor friendly) and you have to get close with a flashlight to see the dust.
Very nice pads.
I stayed with the original O.E. pads didn't want to deal with the squeaking after they get dirty of aftermarket pads, I only paid 85.00 for O.E. pad kit same one you would get from a dealer check them out they seem to have everything here https://www.moparpartsgiant.com/
Discussion Starter #18
I finally got them installed about 3 weekends ago. No issues, all work/stop great. No noise.
1 - 18 of 18 Posts
