1 - 6 of 6 Posts
Hello all new to the forum. I just bought a 2006 hemi r/t with a procharger on it. and custom corso exhaust. the rock runs and drives great. my question is I wonder why i cant do a burn out the car flies chirps the tires in every gear but doesn't melt the tires off. im sure its traction control is it adjustable? and is it off or on when the light on the dash with the car and the squiggly line is lite up?
· Premium Member
Your car doesn't have a "full off" selection for the ESC, only partially off. Even with the ESC light on and Mr. Squiggles light on, it's not fully disabled.
You can turn it fully off with a key trick, using a tuner or by installing a switch to disable it.
Key Trick...
http://www.chargerforums.com/forums/showthread.php?t=49079
No-ESP mod...
http://www.chargerforums.com/forums/showthread.php?t=25225
http://www.chargerforums.com/forums/showthread.php?t=152678
http://www.chargerforums.com/forums/showthread.php?t=126646
You can turn it fully off with a key trick.....
Key Trick...
[/url]
Does the key trick only work for certain models or years? I have a 2009 R/T and the key trick does nothing for me. I've tried it a few times, in park, in drive, sitting still, moving, turn quickly, hold for 5-10 seconds. Nothing. Mr. Squiggles never lights up, BAS never lights up.
The vehicle needs to be in drive and moving at a somewhat decent rate of speed for it to work. I want to say it needs to be above 10 or 15mph. While you're driving, turn the key all the way to the crank position and hold it there until you hear a chime come from the speakers. It should work just fine on your 2009, as we used to do this to my best friend's 2010 Chrysler 300 all the time.
My 07 will work at speeds as low as 1-2 mph. Any registered wheel speed by the abs module will set the lights off. 06's i didnt think worked with the key. Those had a fuse you pulled.
I must not have been going fast enough when I tried it moving before. I've tried it successfully a couple times now ensuring I was going over 20. WooHoo!
1 - 6 of 6 Posts
