Is the pattern 5/115m or 5/114.3?
Because I want to put some BOSS 304's on, and it says that the pattern is 5/4.50 or 5/114.3
I was wondering if that would fit on an 06 R/T
x2The official Charger bolt pattern is 5x115mm / 5x4.53" ...... there are a lot of 5x114.3 / 5x4.50 rims that will fit, but they'll require the use of hub-centric rings, and you still end up with wheel studs that are not centered perfectly within the wheel holes ... this can cause extra stress on the wheel studs and possibly cause one or more of them to break ...
I'd only recommend the use of a 5x115 wheel on a Charger ...
couldn't have said it better.The official Charger bolt pattern is 5x115mm / 5x4.53" ...... there are a lot of 5x114.3 / 5x4.50 rims that will fit, but they'll require the use of hub-centric rings, and you still end up with wheel studs that are not centered perfectly within the wheel holes ... this can cause extra stress on the wheel studs and possibly cause one or more of them to break ...
