1 - 4 of 4 Posts
I pulled the 11,14,16 fuses under the hood
put the ignition into "On", then flipped over to start but heard a chime right away, I still held for 5-10 seconds and heard another chime
I flipped back over to "On" and back to start again and heard the chime right away
The orange engine light in the corner of the far left guage has come on and has not gone off. I checked for any CEL's and there were none
It was stated in the process DO NOT mix up the fuses, which I might have done, but I dont see how putting (2) of the exact same color 25amp fuses in eachothers spot would do anything, its just the amps that matter right?
Double check, if it is okay run the pig and wait and see if it shoots out codes. The CEL should go away if it does not you will see codes.
we just had this conversation a couple nights ago. let me see if i can find it.
1 - 4 of 4 Posts
