Hey guys I have an 06 SRT8, the two front doors both pop when opening and closing, sounds like the hinges are bad, any idea what could be causing this?... Is there a fairly inexpensive fix for it?...
You could probably also listen if it is coming from the front of the door, or the rear of the door!Thanks for the reply, I guess I'm not seeing the area that you're referring to, they appear to be sealed units that I can't get grease into, as I have tried... Could you better describe which area you're referring to, or maybe a pic if possible?...
True! I've actually applied the grease and it still make the popping creaking noise for a day or two, have to reapply, still do it until it finally worked it's way in and now I'm all good, until spring anyway.You could probably also listen if it is coming from the front of the door, or the rear of the door!
If it is coming from the front of the door, that is where the door connects to the car with the hinge.
If it is coming from the rear of the door. that is the area of the door that connects to the car only when it closes!
You probably want to go ahead and apply the white lithium grease to both of these areas anyway!
Yeah, I know my explanation of my process isn't precise, sorry about that, I would take pictures and show you exactly where I do it and all that but I can't at the moment. I spray the hinge and work the door a few times, also be sure to wipe up an accessIt is definitely coming from the hinges, from the noise, I'm guessing both front upper door hinges, but definitely worse on the driver's side as it gets the most use... So you just keep applying lithium grease till it works its way in?...
Here's a quote from the LXForums:Alright, I'll try to get some grease into it and see if it will silence it any... Thanks again for your help... If anyone else has any other ideas or useful information on this issue, please let me know as I'd rather find a permanent fix to the problem if at all possible...lol
Not necessarily, I have the new hinges and still have the problem, it was never actually fixed with the new hinge style, so unless adding grease literally does nothing I wouldn't even bother changing it out. Like I mentioned before I still have to add grease to the hinge from time to time. If you check out the pdf link I posted it shows the new hinge style.The 2006 Chargers used a different door hinge than the 2007 and later models did. It is the upper hinge that's the issue. It was an old Mercedes design that is prone to failing and makes the popping noise. Greasing it won't help (believe me, I've got the same problem). It needs to be replaced.
2006 upper door hinge P/N 5161445AA
2007-2010 upper door hinge P/N 4575747AA
It's actually a different issue on the 2007 and up cars. It is the lower hinge that makes the noise on them (I have that TSB in my files).Not necessarily, I have the new hinges and still have the problem, it was never actually fixed with the new hinges. If you check out the pdf link I posted it shows the new hinge style, same issue.
Well I checked out the link and looked at the difference in the door hinges... Looks like the link is pertaining to the newer style of hinges solely as it only lists 2007-2010 models, and by the looks of their design, they appear to just be an old school step down type hinge, which of course is VERY easy to lube up... Mine is apparently the faulty sealed Mercedez version, which I will try my best to get some grease into... Any other ideas or solutions floating around out there?... My car is absolutely beautiful, till you open the doors...lol
Whoops! My apologies! That sucks the old hinge doesn't even an area to grease up.It's actually a different issue on the 2007 and up cars. It is the lower hinge that makes the noise on them (I have that TSB in my files).
On the 2006 it is the upper hinge that is the issue. The roller assembly is inside the upper hinge on the 2006 and can't be greased to fix the issue and requires replacement. The 2007+ has the roller assembly on the outside of the lower hinge and it can be greased.
I've thought about drilling a small hole in the barrel of mine so I could spray grease inside but I haven't found a diagram of the internal assembly to let me know where the right place to drill would be.Well I checked out the link and looked at the difference in the door hinges... Looks like the link is pertaining to the newer style of hinges solely as it only lists 2007-2010 models, and by the looks of their design, they appear to just be an old school step down type hinge, which of course is VERY easy to lube up... Mine is apparently the faulty sealed Mercedez version, which I will try my best to get some grease into... Any other ideas or solutions floating around out there?... My car is absolutely beautiful, till you open the doors...lol
