hi guys
today i have a transmission problem suddenly
i start the engine then i try to shift from the park it did not move !!!!!
i thought it maybe from the break lock but no i pass the break locker but
the gear did not move down to reverse (R) or (D)
can you help ?
thanks
Sounds as if the brake pedal switch might be borked. Can you hear the little lock actuate when you step on the brakes? Also, I think there is a manual override for just an occasion. ( not sure where it is) Look in your owners manual.
ooh man i'm too late. i wanted to help too.
