1 - 20 of 23 Posts
well where to start, hit some big dead animal on the road, yellow check engine light is on lower left side dash, pushed and held trip reset while turning key and 4-11 came up. what code is this. or is this a version of my computer the car has on board. help pleasssssseeeee:knockout:
WHAT KIND OF ANIMAL WE TALKING ABOUT:knockout:
0038 is 1/2 heater curcuit heater high, what does this mean
basically it means the 02 sensor has some issues. it could be something as simple as frayed wiring or a deattached wire from impact. should be an easy fix. heres the manual direction for testing. or just get under there and check the wire paths.:grin:
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
For a complete wiring diagram Refer to Section 8W.
9 - 24 ENGINE ELECTRICAL DIAGNOSTICS LX
² When Monitored:
Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off.
² Set Condition:
Desired state does not equal Actual state. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
(K299) O2 1/2 HEATER CONTROL CIRCUIT OPEN
(Z902) O2 1/2 HEATER GROUND CIRCUIT OPEN
(K299) O2 SENSOR 1/2 HEATER CONTROL SHORTED TO BATTERY VOLTAGE
O2 SENSOR
PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE -
DIAGNOSIS AND TESTING).
Diagnostic Test
1. ACTIVE DTC
Ignition on, engine not running.
With a scan tool, read DTCs.
Is the DTC active at this time?
Yes >> Go To 2
No >> Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
Perform the POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
2. O2 HEATER ELEMENT
Turn the ignition off.
NOTE: Allow the O2 Sensor to cool down to room temperature.
Disconnect the 1/2 O2 Sensor harness connector.
Measure the resistance across the O2 Sensor Heater element, between the Heater Control terminal and the Heater
ground terminal at the component.
NOTE: O2 Heater Element resistance values should be measured at 70°F (21.1°C). The resistance value will
vary with different temperature values.
Is the O2 Sensor Heater Element resistance between 2.0 and 30.0 ohms?
Yes >> Go To 3
No >> Replace the O2 Sensor.
LX ENGINE ELECTRICAL DIAGNOSTICS 9 - 25
3. (K299) O2 1/2 HEATER CONTROL CIRCUIT
With a scan tool, actuate the O2 1/2 Heater Test with the O2 Sensor
harness connector still disconnected.
Using a 12-volt test light connected to ground, probe the (K299) O2 1/2
Heater Control circuit in the O2 Sensor harness connector.
Does the test light illuminate brightly and flash on and off during
the actuation?
Yes >> Go To 4
No >> Go To 5
4. (Z902) O2 HEATER GROUND CIRCUIT OPEN
Measure the resistance between an engine ground and the (Z902) O2
1/2 Heater ground circuit in the O2 Sensor harness connector.
Is the resistance below 5.0 ohms?
Yes >> Replace the O2 Sensor.
No >> Repair the open in the (Z902) O2 1/2 Heater ground circuit.
5. (K299) O2 1/2 HEATER CONTROL CIRCUIT SHORTED TO BATTERY VOLTAGE
Disconnect the PCM harness connectors.
Measure the voltage on the (K299) O2 1/2 Heater Control circuit in the
Does the voltmeter indicate any voltage present?
Yes >> Repair the short to battery voltage in the (K299) O2 1/2
Heater Control circuit.
No >> Go To 6
9 - 26 ENGINE ELECTRICAL DIAGNOSTICS LX
6. (K299) O2 1/2 HEATER CONTROL CIRCUIT OPEN
CAUTION: Do not probe the PCM harness connectors. Probing the
PCM harness connectors will damage the PCM terminals resulting
in poor terminal to pin connection. Install Miller Special Tool #8815
to perform diagnosis.
Measure the resistance of the (K299) O2 1/2 Heater Control circuit from
the O2 Sensor harness connector to the appropriate terminal of special
tool #8815.
Yes >> Go To 7
No >> Repair the open in the (K299) O2 1/2 Heater Control circuit.
7. PCM
NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal
push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and
Ground circuits.
Were there any problems found?
Yes >> Repair as necessary.
No >> Replace and program the Powertrain Control Module per Service Information.
I believe what I hit to be a deer, it was already dead. Oh my, what a horrible sound. I was under the car this morning and removed engine cover. that was in about 3 pieces. With further investigation found the down range o2 sensor on the right side was unplugged. I plugged it back in and re-hung it in its place and secured it with a zip tie due to the fact that the plastic hanger it once was secured with from the factory was no longer there. I know need an engine cover. If that cover was not there i'll almost bet there would have been more damage. damage to the steering rack and other lines in the bottom of the engine bay. The battery was re-connected and car started, check engine light extinguished and car is running as it did before. I need to replace that engine cover. where can i get one and for how much?
really?? was it at night or something??:confused:
3:30 in the morning. I have to leave that early because i work in tampa fl. at this time. Money is good, drive is to far.
i know what you mean!! im in the same boat! 35 miles each way.....i bet that delayed your trip huh??
I drive 100 miles each way, like i said, money is great. damb drive is killing me and killing my cars value
I know what you mean!! i already put 25,000 on my car........
foun code. it is 0038 researching now
After finding the code where did you look it up. My car is showing code h 1224 dont know where to research it
1 - 20 of 23 Posts
