I just got my Predator today and will be installing the 93 octane CAI tune. I previously had my car flashed at the dealer to change shift points because of some lag between 1st and 2nd and in reverse. My question is do I need to have that removed or because it is a DCX tune it will be ok?
If when you plug in your predator if it tells you that you need an update then you go to diablosport.com/dcx, then you download the update and you are good to go. If it doesn't tell you to download and update, you can just go right a head and install a tune on your car.
man with all the good questions someone should compile the questions and answers into one main thread
I think that is living over on LX forums
Discussion Starter #5
Thanks for the info.
Ed
