Just installed the Pred last nite on my Sublime. It is awesome. I even did some custom tuning by richning up the fuel mix at all rpm levels by 1 click, advanced the timing at all levels by one degree and firmed the shifts. I know some are scared to custom tune w/out a dyno, but I just added a bit more fuel to compensate the timing change, which is better than being lean. Aftermarket intakes tend to cause the engine to run a tad bit leaner, I would think that adding a tad more fuel wouldn't hurt. Better than fried rings or pistons from over lean conditions.
Also, I have an oil change scheduled for Saturday morning. Should I revert back to stock just for this? Or should I just keep an eye on them and tell them to only change the oil?
Thanks y'all.
Thanks y'all.
