1 - 2 of 2 Posts
I have installed the CAI per. tune on my '07 PC daytona. I disabled the ESP(with lights,ESP,BRAKE,and TC lit) but when I restarted the car today, the lights have disappeared as if the progam is not installed and I can use the ESP button to disable TC. I also raised/disabled autoshift in the autostick pos. and noticed that it still upshifterd by itself at about the same point as before.
I have also tried the QA buttons. Are they just for immediate use and have to be reset every time the car is restarted? (hence Quick Adjust)
The shift firmness is slightly better but nowhere near where I thought? heard it should be.
Is my Predator working? :confused: I did'nt get the update message when I installed it 1st time.
The quick adjusts should keep until you do a new program or turn them off via quick adjust. The exception should be the ESP disable. If you do an ESP quick adjust it will remain on until you reprogram/QA OR press the dashboard ESP button and cycle the ignition.
1 - 2 of 2 Posts
