GUys i have the 180 stat. My question is there are 6 settings for fan in the predator menu and then the 3 other fan settings in a seperate location. What do I set each of these at. I know the 3 I want at about 198 -hugh- 195 mid and 190 low, but what about the 6 other settings what do I set those too?
6 settings are for the ac being off. there is a high mph and a low mph temp settings and then the 3 others are for when the ac is on and those are just high mid and low. take your settings and just put them in the similar pattern to what i have below but with the temps you want (note the temps i have listed are for a stock thermo with the predator perf 91 oct CAI tune)
ac off
High MPH HS 226.39
High MPH LS 217.39
High MPH MS 226.39
Low MPH HS 226.39
Low MPH LS 217.39
Low MPH MS 226.39
ac on
HS 226.39
LS 217.39
MS 226.39
zoom zzoom i know he tells us what to set it at but the problem is he says drop it by 5 incrments and he figures it starts at 198 mine started at 230 so if i drop by 5 i dont think it will help with 180 stats. I need actuall #'s someone must be using 180 stat and has the #'s
dang did you try going to the diablo forums or send a pm to christy on here?
What he stated was that the settings that were set on the first install were 198, they have since updated, and the settings were taken out on the later update, the 198 was aref. point, I started at 200, and went 5 down from there. setting them 5degrees apart. use 200 as a starting point. this is so your fans don't stay on so much.
so in other words the 6 settings start at 200-195-190-185-180-175? and the 3 seperate fan settings set them at 200-195-190?
