So the other day, I go & fill up at a gas station. I turn the car off and fill up. When I'm leaving and Im heading out into traffic, Im noticing that my RPMs are getting higher and higher as Im pressing on the gas, but the car isnt shifting out of first. I try to lay off the gas to bring the RPMs down (and possibly reset the trans.) then I gradually press on the gas again... 3000rpm...4000rpm...5000rpm w/o shifting back down. As soon as possible, I pull over to the side and turn the car off and back on. Luckily that worked and reset the system. This is the 2nd time this has happened to me. The first time, I was sitting parked and idling for a lil bit while I was inputing data in the nav unit. When I put the car in D and started going it just wouldnt shift out of 1st gear. Anyone else had this problem or know what could be the possible cause? I have a feeling if I take it to a dealership, they are going to look at me like Im crazy b/c its not something that happens all the time and probably wont happen when I take my car to the shop... Any ideas?
