Hey everybody
So I have had my 2007 D. charger for almost 3 years now I have never encountered this problem… Heres a quick recap of prior to the issue- I was driving my family like normal then suddenly my AC starts turning off and on, later my radio turns out.. I parked the car, turned it off and when I tried turning it on it was a no go.. I figured it was the battery or the alternator and surely enough it was the alternator…… I went out and bought a used one for 60 bucks but the connection was not right.. Heres where it gets weird… I took the connector from the old alternator (mine-defective) and replaced it with the one that was used thinking it would work.. tried it and no luck…. So I ended up buying a new one for 160 from autozone and when I replaced the alternator my car started acting up badly..
1.the car would need a jump to start
2. the engine kept acting as if it had too much air flow or not enough.
3. my RED LIGHTING BOLT light kept coming on and flashing
4. my yellow car light (ESP?, ESB?) light would stay on as well.
5. The car is not driveable what so ever. It throws codes like 2017 and sometimes like a 0513 vode?
6. The car smells bad from exhaust and it still shakes very badly.
7. Brake is super hard to press on and pressing on the acceleration does nothing, not eve rev..
So I tired a new MAP sensor and no go… I tried cleaning the PCM-MAP-and TP sensor and no go still… its weird how all this happened from an alternator swap???
I did replace the battery but still no good.. I even tried some ideas I read on different forums like touching the neg and positive battery connectors to restart ECM but no luck.. I tried pulling the fuse 11 from the back and front fuse box and still nothing… ive been hearing that it could be a PCM issue? Is this true. Someone with the same issue please help..
[email protected]
[email protected]
