1 - 4 of 4 Posts
Check your owner's manual. If they're Iridiums, the service interval should be 100,000 miles.
IIRC, the 100K plugs did not come on scene until late '13, or early '14. The build date on my '14 was 09/13, and it has the iridiums. Before that, they were Champion coppers with a 30K interval. You can run them 50K, but I would consider that the limit.
Don
Factory plugs for the 2012 5.7L are NGK LZFR5C-11 (Gap 0.043 in.). Scheduled replacement is every 30K miles. They're copper core plugs with nickel electrodes. Torque is 18.5 - 22 ft. lbs. depending on whether they are installed wet or dry. I installed mine wet (anti-seize grease) at 19 ft. lbs. NGK says the threads have a metal plating that provides anti-corrosion and anti-seizing; so they can be installed dry. The factory installed plugs were installed dry ... but the Hemi heads are aluminum so I prefer to put a little anti-seize grease on the threads. Whether you install the plugs wet or dry, apply dielectric grease to the inside of the spark plug boots.
1 - 4 of 4 Posts
