Back Story -
So, I got the car 2 weeks ago, sh\*t hits the fan now its at the dealer after paying a mechanic 2k just to get it towed out from that shop after a rushed signature that gave them rights to take hostage of my car. Now its at the right place beginning to get fixed.
I have a 2018 Dodge Charger Daytona (5.7)
Now I want to take advantage of the situation by replacing my destroyed rims after the crash with (Ferradas CM2) rims. I also want to stagger it but I do not know what size rims to run along with the tires on those rims. I do plan on adding lowering springs later on if that is a factor.
Now my last questioning is whether the car will be effected in matters of torque and hp if I can still spin those tires and do donuts in general, the feel of the car.
Thank you.
New wheels?
PCD - 5x115
Depending on whether you want staggered or squared - I'd stick with 20x9 - 10.5
Avoid 22's -rough ride unless you have a show car.
Should be an easy decision for you - they even had a gallery with different combinations..
I appreciate your comment! Now what exactly does staggered and squared do? Is it worth it on a 5.7? Will it slow down since they may be heavier rims and bigger tires?
