1 - 2 of 2 Posts
Please Help Me & Give Me Exact Directions on Changing Spark Plugs on my 2008 3.5!!??
I need some serious help! I am confused on how I need to replace my spark plugs and which ones I should use. I need to know how to do this myself exactly and I can't seem to find it out!?? I got platinum but I see that some say that is the correct ones and others say it is not.......please tell me which ones I need to get and use and how to change them step by step!!! And what else needs to be changed at the same time if there is anything?????? PLEASE!!!! Thanks!!
· Premium Member
Check out this PDF of the 2.7L V6 spark plug change, pretty much the same thing except it's a 2.7 not a 3.5. Also, you can find some video tutorials specifically for the 3.5L on YouTube, also Google netted a ton of results. Good luck!
Spark Plugs: ZFR5LP–13G (Gap 0.050 in [1.27 mm])
For any other maintenance, just check out your manual, if you don't have a manual you can download it for free off Dodge.com I'm still on my same plugs at around 111K miles, even though it says to change them around 102K miles or something like that. So unless your mpg has plumeted or throwing codes or anything your plugs are probably fine :D Though you can't beat preventive measures, I guess I like living on the edge lol
1 - 2 of 2 Posts
