1 - 9 of 9 Posts
I`ve had my charger for 2 years and 2-3 times in the past a red flashing light on the dash has gone off and I`ve had to cut car off and restart for it to move.It did it again 2 days before today. Like something might not be registering for the transmission. Well now the car is stuck in park and the light comes on. People say it`s the pink thingy but there`s no mention in all the searches I`ve done about the red light coming on. It`s broke down on a 3rd floor parking garage(really tight). Can anyone help direct me to what this could be? Thanks Travis BTW,the car is a 2008 dodge charger r/t
ok,thanks.i didnt think it did.
Discussion Starter #4
any other ideas??
is it the security red dot on the dashboard? try disconnecting battery and touching the wires together for afew seconds and wait afew minutes and put them back on
Discussion Starter #6
my predator erased the code U0101. Car is finally running but code came back. Now my ac/heater controls don`t work at all. I`m seriously thinking of trading it now. I`ve never had so much problems with something
Discussion Starter #7
I went and bought a haynes manual and they don`t even list which fuses are which
Here ya go..
Front Power Distribution Center (2008-2010)
#1 - 15 Amp - Blue- Washer Motor
#2 - 25 Amp - Neutral - Powertrain Control Module (PCM) --- pull this fuse for 30 seconds to clear TCM adaptives
#3 - 25 Amp - Neutral - Ignition Run/Start
#4 - 25 Amp - Neutral - Alternator/EGR Solenoid
#5 - (empty)
#6 - 25 Amp - Neutral - Ignition Coils/Injectors/Short Runner Valve
#7 - (empty)
#8 - 25 Amp - Neutral - Starter
#9 - (empty)
#10 - 30 Amp - Pink - Windshield Wiper
#11 - 30 Amp - Pink - Anti-lock Brakes System (ABS) Valves
#12 - 40 Amp - Green - Radiator Fan
#13 - 50 Amp - Red - Anti-lock Brakes System (ABS) Pump Motor
#14 - 60 Amp - Yellow - Radiator Fan
#15 - 50 Amp - Red - Radiator Fan
#16 - (empty)
#17 - (empty)
#18 - (empty)
#19 - (empty)
#20 - (empty)
#21 - (empty)
#22 - (empty)
Rear Power Distribution (2008-2010)
#1 - 60 Amp - Yellow - Ignition Off Draw (IOD)
#2 - 40 Amp - Green - Integrated Power Module (IPM)
#3 - (empty)
#4 - 40 Amp - Green - Integrated Power Module (IPM)
#5 - 30 Amp - Pink - Heated Seats
#6 - 20 Amp - Yellow - Fuel Pump
#7 - (empty)
#8 - 15 Amp - Blue - Diagnostic Link Connector (DLC)/Wireless Control Module (WCM)/Wireless Ignition Node (WIN)
#9 - 20 Amp - Yellow - Power Outlet
#10 - (empty)
#11 - (circuit breaker)
#12 - (circuit breaker)
#13 - (circuit breaker)
#14 - 10 Amp - Red - AC Heater Control/Cluster/Security Module
#15 - 20 Amp - Yellow - Trailer Tow Brake Module
#16 - (empty)
#17 - 20 Amp - Yellow - Cluster
#18 - 20 Amp - Yellow - Selectable Power Outlet
#19 - 10 Amp - Red - Stop Lights
#20 - (empty)
#21 - (empty)
#22 - (empty)
#23 - (empty)
#24 - (empty)
#25 - (empty)
#26 - (empty)
#27 - 10 Amp - Red - Occupant Restraint Controller (ORC)
#28 - 10 Amp - Red - Ignition Run/AC Heater Control/Headlights/Occupant Restraint Controller (ORC)
#29 - 5 Amp - Orange - Cluster/Electronic Stability Program (ESP) /Powertrain Control Module (PCM)/Stop Light Switch
#30 - 10 Amp - Red - Door Modules/Power Mirrors/Steering Control Module (SCM)
#31 - (empty)
#32 - (empty)
#33 - (empty)
#34 - (empty)
#35 - 5 Amp - Orange - Antenna Module/Power Mirrors
#36 - 20 Amp - Yellow - Hands Free Phone/Video Monitor/Radio
#37 - 15 Amp - Blue - Transmission
#38 - 10 Amp - Red - Cargo Light/Satellite Receiver (SDARS) Video/Vehicle Information Module
#39 - 10 Amp - Red - Heated Mirrors
#40 - 5 Amp - Orange - Auto Inside Rearview Mirror/Heated Seats/Switch Bank
#41 - 10 Amp - Red - AC Heater Control/Headlights/Tire Pressure Monitoring
#42 - 30 Amp - Pink - Front Blower Motor
#43 - 30 Amp - Pink - Rear Window Defroster
#44 - 20 Amp - Blue - Amplifier/Sunroof
Discussion Starter #9
thanks:rocker:
1 - 9 of 9 Posts
