Was curious if any other 2015+ charger owners have this issue as well. It’s not a big issue because you never see the damage, but under the truck lid by the latch where the seal on the bumper meet, there seems to be some rubbing of some kind that is damaging the paint across the entire area where the seal lines up.
Does anyone else have this? Want to see if it’s common, otherwise I may try to adjust the trunk as it may be misaligned or something.
291909
291910
291911
291912
That's just the seam weld on the weather strip. It's thicker and more stiff at the seam which causes it to rub on the trunk.
I ran a 4 inch strip of teflon tape along the surface of the trunk as a chaff guard when I noticed the wear. It's not thick enough to affect sealing so it doesn't leak water.
thanks for the info, I will try this!
