I have the dreaded P06DD code on my 2012 Charger V6. I've verified the correct Mopar oil filter, oil weight and changed it twice now. I've also changed the oil pressure sensor under the intake. Code keeps coming back eventually.
I'm guessing it's time to drop the oil pan and go to work. It seems the solenoid on the dual stage pump is likely the issue. I've watched several videos on replacing the pump, but they were on FWD cars.
1. Is this easier or harder on the RWD engine? Are following the FWD videos enough to get the job done, or are there other issues I need to know?
2. I see the now they sell just the solenoid. Can the solenoid be replaced without pulling the pump?
Any other advice is appreciated. Thanks!
