Hello all, my car has been getting the p0303 fault for some time now, I’ve changed spark plugs, changed that specific ignition coil and it did not fix the issue. The light flashes at times. Any suggestions on what the problem could be. Have 6 brand new fuel injectors otw, hopefully that fixes it, if not im at a loss. Maybe broken head gasket or leaking maybe. Also there is no vacuum leaks
Good morning Zach, and welcome to the forum:
It sounds like you have ruled a number of things out. At this point, I would expect to find a valve or valvetrain issue. I would run a compression check. A flashing CE light indicates cylinder misfire, which is not good. I believe the 2.7's are known for some rocker arm issues once they get up in the miles. How many miles on your Charger?
Don
