1 - 20 of 24 Posts
It's exactly the same stuff. Looks like G2 is the only company that makes a purple caliper paint. I take it that you aren't happy with the color, Amanda? :(
I wonder if I can take red and blue and mix them together. :)
Alloy wheel Tire Rim Wheel Spoke
The color is ok.. It is going to be changes to black one day...
I would try that! See if it works & let me know!
Looks good to me. Dodge parts dept. will also order a half pint for you for a perfect match, unless you want to consult a custom painter, or even an auto paint shop.
im no paint epert but what if you mixed in a little black, would that darken it up color base wise without taking away from the purplish hue?
Tom
Pretty color but does it go with the car?
Does anyone know if you can mix colors of caliper paint? :)
It does go with the car it is a cool contrast! I just would have prefered a more lavender / purple then the pink / grape that it is.. I get compliments on it from women.. A few guys have given me bs on it :)
Tom
It might have but I didnt have any heat resistant black paint laying around! And you also have X amount of time to put the paint on before it hardens,
Go with the black, and while you're at it, paint the rotor hubs. I'm trying to find my pics for you to look at.
Finally found it
CC, you can get touch up paint cheaper from your dealer! Still wouldn't use it tho. you could see if they make a white caliper paint and have your friendly neighborhood hardware store attempt to color it for you. Color may or may not be able to be matched, and I have no idea what impact household paint pigments will do to the paint and it's longevity. I didn't go with Black because it was easy, I went with it because i thought it would look best. Another thought, If they have a red and blue kit, try mixing the two colors together to get purple. Not sure what the R/B mix would be to best match, but you could always start at 50/50 and adjust from there.
1 - 20 of 24 Posts
