1 - 8 of 8 Posts
what are you guys using to remove the canister to change the oil filter. its a 2011. its on the top so its easy to get to but i just cant get it to twsist off. I'm also having the same problem with my wifes durango
Doesn't a 24mm socket work?
I know that the Mobil One and the K&N are supposed to able to be done with a socket, but I never found it very usable. And realistically, you should only ever have to use a filter wrench once on any vehicle, because being a good mechanic, you never put one on more than hand tight :)
this is the only one I have, have had it for maybe 18-20 years, and it's very flexible, between u-joints and extensions, you can get at almost any filter out there.
http://www.toolsource.com/inch-drive-filter-wrench-3716-inch-95mm-p-71090.html
15/16 Socket for Canister Removal
I just happened to have a 15/16 on a 1/2 drive socket laying around. That's what I use to remove the canister. Just use to ratchet to get it started then I'll take over by hand. Remember to keep in mind plastic threads...
1 - 8 of 8 Posts
