Ok so I changed my oil this weekend as I have done so many times but this time was different. I had bought my oil the day before. Well anyway I take the time to jack my car up put it on the stands remove the plastic shielding from under the engine and guess what. I realize I forgot to actually warm up my car. Anyway I'm wondering if it's possible I didn't get all the oil out. I let it drain for 45 mins cuz it was cold. Now when my engine is warmed up my oil pressure is at 22psi, which I think is a little high. Cold my oil pressure at idle is 54psi. Looking at my dipstick it doesn't look like I overfilled. There is a slight bit of oil on the upper part of the dipstick, but it only looks like it's concentrated in the actual part of the dipstick that's marked "safe".
Does it sound like I overfilled my oil, or should I be ok?
Ooops forgot to add I used Mobil 1 5w20 so I did use the right weight.
