I got my oil changed 5/11, and the change oil message has been on for a few weeks now. I haven't even driven 2000 miles since then. What could be going on?
was it reset?I got my oil changed 5/11, and the change oil message has been on for a few weeks now. I haven't even driven 2000 miles since then. What could be going on?
It's on the EVIC, says "Oil Change Needed" (or somethign like that), with a ding, followed by saying "Contact Dealer".that is odd...
You have a newer charger right? Is the message through the NAV (if it's through here it is set to just go off on an interval) or do you have an actual oil life indicator?
Most cars oil change systems are done on an algorithm. Throttle position x mph x stop and go x time....usually.I believe so. After I got it changed, it didn't go off for about 1.5 months.
I'd heard about the algorithm. I do a bunch of stop&go driving, and enjoy the feeling of full power, even if I'm only going up to 25 in a residential. Since I do ride it pretty rough, I wasn't sure if I'd need to change it more often, especially this often, even with full synth oil.Most cars oil change systems are done on an algorithm. Throttle position x mph x stop and go x time....usually.
Some upper end cars like the Cadillacs have the algorithm and two metal plates that measure the resistance between them as the oil passes through them. When there is enough conductivity due to the ferrous metal content, it compares to the algorithm and then turns on the light or message on the dashboard.
I believe on the chargers that it is simply the algorithm so change the oil based on mileage like in the old days and forget the "onboard system" because it is inaccurate.
Thanks
Brian
BND Automotive LLC
440-821-9040 :bigthumb:
One important way to protect your engine is to use QuantumBlue Competition Formula 7.5w23 Motor oil. Also adding to it the ACES IV Gasoline Formula Fuel Catalyst that lubricates the upper cylinder reducing bore wear by 600% with stem and guide area wear being reduced by 360%.:clap:I'd heard about the algorithm. I do a bunch of stop&go driving, and enjoy the feeling of full power, even if I'm only going up to 25 in a residential. Since I do ride it pretty rough, I wasn't sure if I'd need to change it more often, especially this often, even with full synth oil.
