1 - 11 of 11 Posts
I have a set. they are stamped "lightweight" on them.
what is the actual deal with them? I bought them used a while back. I dont ever see anyone else with them stamped "lightweight"
what is the story with them? seems like they would be better or worth more than all the copy cats . even my buddie's 2022 scatpack doesnt have anything stamped on his .
stamped "lightweight" on one side and "MOPAR" on other
Tire Wheel Automotive tire Vehicle Tread
It just depends, some came with the lettering, others didn't. They're the WRTs correct?
2017 Scat Pack. Procharged 426. 850ish on pump 93
First set is 9.5 inches.
I know what the second set is , I bought them brand new.
There's a reason they stamped "lightweight" on the Scat Wheels (came with the dynamics package). The 20's weigh like 25 or 27lbs vs the 33+lbs of the other wheels.
Performance wise, that 5lbs per corner makes a world of difference.
Yeah factory WRT wheels are 20x9 and are great because you can fit any spindle with the 19.2 or 19.7 mm offset. The black ones some of them had the Mopar Lightweight stamped on them and they were also sold from the Mopar catalog like that. I've never seen the granite/charcoal ones with that stamp only the flat black ones.
If you look on ebay you'll see sellers that have the packaged wheels with a Mopar center cap (that's how they came in the Mopar catalog circa 2015).
Reactions: HemiLonestar
Are those early wheels on Charger 19.2 mm offset? I know on Challenger those early wheels WRT marked Mopar and Lightweight had an 18.5 mm offset.
1 - 11 of 11 Posts
